Recent update [139] changed the size of text of bookmarks in folders in the bookmark toolbar
  • Akukho zimpendulo
  • 0 inale ngxaki
Updated recently from (I believe) 138.04 to 139.0.1, and immediately noticed that the size of font (and icons) had changed in the folders I have in the bookmark toolbar, that is they are much smaller and thus also less space between. Why this, and is it possible to change the size, without changing something else?
It's possible that many don't have folders in the toolbar and thus don't notice, but I have 2-3 apart from bookmarks.
I remember a change many versions ago that increased the space between entries in the bookmark menu, and also in the bookmark toolbar folders. That was too much and I found a setting [in config] that could be changed to decrease the space back then. (I haven't looked for that solution now, probably have some doc somewhere, and won't bother searching since this is different. Same with this case; I did some quick initial search but found next to nothing and older. BTW, this is one of the downsides of changes like these and similar; the day you have too move to another OS version, i.e. reinstall everything you also have to keep documentation of all these little changes, apart from all the other things you'll have to export or save.)
Updated recently from (I believe) 138.04 to 139.0.1, and immediately noticed that the size of font (and icons) had changed in the folders I have in the '''bookmark toolbar''', that is they are '''much smaller''' and thus also less space between. Why this, and is it possible to change the size, without changing something else? It's possible that many don't have folders in the toolbar and thus don't notice, but I have 2-3 apart from bookmarks. I remember a change many versions ago that '''increased''' the space between entries in the '''bookmark menu''', and also in the bookmark toolbar folders. That was too much and I found a setting [in config] that could be changed to decrease the space back then. (I haven't looked for that solution now, probably have some doc somewhere, and won't bother searching since this is different. Same with this case; I did some quick initial search but found next to nothing and older. BTW, this is one of the downsides of changes like these and similar; the day you have too move to another OS version, i.e. reinstall everything you also have to keep documentation of all these little changes, apart from all the other things you'll have to export or save.)
